Hello from Calshot near Southampton
Re: Hello from Calshot near Southampton
Postby Fury1630 » Sun Feb 10, 2013 6:18 pm
Nash wrote:Agree with Tony on this over pressure on the needles is normally critical. Not sure about the 3psi figure though. That sounds low to me as on a Jenvey TB setup the pressure regulator is set to 3.5 Bar but someone will have a better view on what the pressure should be.
Throttle bodies need pressure to squirt the fuel, whereas carbs use the engine airflow to draw the fuel through, so want just a little positive pressure to keep the float chamber topped up.
Sorry Dean your "hello" thread's gone a little awry - it happens round here. :lol:
Postby Nash » Sun Feb 10, 2013 6:21 pm
Interesting. so what produces the 3 PSI ? a fuel pump of some description?
......Neil
Postby Fury1630 » Sun Feb 10, 2013 6:27 pm
Nash wrote:Interesting. so what produces the 3 PSI ? a fuel pump of some description?
Yep, that's why there are "low pressure" fuel pumps, for carbs & "injection" pumps for - erm - injection. To Invade Dean's thread a little more, engine's with mechanical pumps don't have a problem as when they're not using much fuel (at idle) they don't make much pressure. When you use an electric pump the flow is constant, so at idle the pressure can build & overcome the needle valve. So you need a pressure regulator to cap the pressure.
Postby Nash » Sun Feb 10, 2013 6:33 pm
......Neil
I knew there was a difference but I wasn't aware there was such a difference in pressure. I've learned something new today.
Ta............. Neil
bigstuff
Postby bigstuff » Sun Feb 10, 2013 7:43 pm
Just to put things into perspective, Neil your 3.5 bar is 50.75 psi, quite a difference ! :D
Nick
Postby Nick » Sun Feb 10, 2013 7:51 pm
Hi Dean, glad to see a proper engine car has joined the forum.
I run a 2.1 Vulcan pinto with an Fr33 cam arp bolts the works..
DeanS
Postby DeanS » Sun Feb 10, 2013 8:26 pm
Nick wrote:Hi Dean, glad to see a proper engine car has joined the forum.
Nick, that sounds sweet! In answer to the over fuelling issues above I was led to believe you must use the bikes electric pump which runs at 3 psi, I couldn't believe how gently it ran!
I bought a fuel pump blocking plate off eBay and bye bye mechanical fuel pump thereby freeing up at least a fifth of a horsepower! :)
Red27
Postby Red27 » Sun Feb 10, 2013 8:35 pm
Welcome Dean, I like the way you said that - "improving" your car. I see you've sussed that photos are required from the outset, but not knowing how to post them is not an excuse :D :D
All types of cars and engines are welcome, and as you can see there is plenty of advice on offer - whether you've asked for it or not :lol:
Linda
DeanS
Postby DeanS » Sun Feb 10, 2013 8:40 pm
Red27 wrote:Welcome Dean, I like the way you said that - "improving" your car. I see you've sussed that photos are required from the outset, but not knowing how to post them is not an excuse :D :D
Hi Linda
It's just that I want to post pictures when "Grin" is finished not while he's still a project :oops:
bigstuff
Postby bigstuff » Sun Feb 10, 2013 9:23 pm
You'll be accused of it being too shiney :D
