Hi there,
I'm based near 7 dials in Brighton. So if you see a yellow Tiger about with a black nose cone it's probably me.
New member from Brighton
- russtik
Re: New member from Brighton
welcome i hope you get the lights sorted on saturday and take it for a run as you know those tigers like to be in prides.
- russtik
Right well I went to the garage today, stuck a new 10amp fuse in and it popped straight away. The ignition wasn't even on. Tried some lights and noticed the o/s rear indicator wasn't working so removed the wheel and started investigating the wiring in the arch.
Turns out the number plate light was knackered and shorting out which consequently melted the loom going to the lights due to the 35amp fuse
(see attached photo). I've cut some bits of loom out and patched it up and I now have working lights again
- Attachments
- Melted loom
- loom-melt.jpg (256.18 KiB) Viewed 1799 times
Good news, see you at Buck Barn tomorrow then??
- russtik
warthog wrote:Good news, see you at Buck Barn tomorrow then??
Yep!
Excellent, looking forward to meeting you, if you have a tomtom give me a shout and ill send you the route
