No Longer Wanted: starter motor for Zetec 2.0 Silvertop
Mattijs
Re: Wanted: starter motor for Zetec 2.0 Silvertop
Postby Mattijs » Tue Sep 11, 2012 6:03 pm
James, what the ... are you doing in my thread?
Russ, David, Tony, thanks for the suggestions. I might try the scrap guys first tomorrow, I can do that before work. I'd like to be back on the road again (perhaps briefly, ya never know, right?) before the weekend. Got a big driving day coming up next Tuesday. Or is that a secret?
Larkingabout
Postby Larkingabout » Tue Sep 11, 2012 6:08 pm
Merely following marks comments. Still a bloody disgrace
Mattijs
Postby Mattijs » Tue Sep 11, 2012 6:17 pm
Ah, that's OK then.
Tony, I basically only need the solenoid. If I cannot find anything, would you consider letting go of the old motor, or just the solenoid?
Postby Tony B » Tue Sep 11, 2012 6:34 pm
Mattijs wrote:Ah, that's OK then.
Yes, no problem, its sitting in my garage gathering dust, whats happening next Tuesday?
Postby Tony C » Tue Sep 11, 2012 6:52 pm
If we told you we'd have to kill you :lol:
Postby locost220 » Tue Sep 11, 2012 8:38 pm
Matt, your getting far to good at this
:D :)
Mattijs
Postby Mattijs » Wed Sep 12, 2012 11:50 am
Went to the Breakers this morning, and got a shiny new (i.e. old and surprisingly clean) starter motor. With four weeks of warranty! Even if you put it in a kit car!
The old starter motor is from a Sierra or Granada. Quite rare ($$$!) and not the same as the normal Zetec one. Tony, the solenoid is completely different, so I won't be able to use it with this motor.
Postby graham b » Wed Sep 12, 2012 12:03 pm
tony b wrote....
"whats happening next Tuesday?"
well its like this.....
cant say really 8-)
Postby David T » Wed Sep 12, 2012 12:55 pm
Mattijs wrote:Went to the Breakers this morning, and got a shiny new (i.e. old and surprisingly clean) starter motor. With four weeks of warranty! Even if you put it in a kit car!
My understanding is that the starter motor needs to match the flywheel & ring gear. So on my Zetec I've got a (lightened) Pinto flywheel & ring gear and so have a Pinto starter.
Postby Nash » Wed Sep 12, 2012 5:24 pm
you need to make sure the bendix disengages from the ring gear otherwise it will destroy the starter. The issue on our cars is normally around the lightened flywheel. So check it out Mattijs
