Bike carbs woes
Re: Bike carbs woes
Not yet Colin, going to have a play myself first.
Re: Bike carbs woes
Maybe late to the party
But my issue with my Keihin was the O rings on the float valve housing with the float needle seating and the O ring on the housing letting by filling the manifold..
Also the silicon rubber manifold rubbers do leak after a little while and I have changed them to a different material ( Rubber petrol pipe)
Also running at 2.5 PSI fuel pressure with 1.8mm main 45 pilot and half a screw out on the mix screw..
2.0 litre zetec fast raod cams 40mm keihin weber management.
Drop me a note if you want any more info..
Gazz
Gazz
Re: Bike carbs woes
All info noted Gazz
