Crate Zetec ready to install Cheap as Chips !
Ben_Copeland
Re: Crate Zetec ready to install Cheap as Chips !
Postby Ben_Copeland » Mon Apr 05, 2010 7:18 pm
zxr400 wrote:didnt know were to post this ,but my mate wants a kit car he can fit in , 6ft3 he's a big lad, 21 stone, ie needs big kit, any comments please ?cheers paul
Paul, your causing trouble again lol (Laugh Out Loud) ;)
Try a new thread in car section.
Ben
Postby jeffw » Thu Apr 08, 2010 9:51 am
Update on this thread. At Detling I spoke with GPS (Zero kitcar boys) who will provide a crate Zetec 2.0 Blacktop), 45mm Jenvey TB's, injectors and fuel Rail, manufold, linkage and TPS sensor for "£2,200 inc the VAT
Plus
Sump (Raceline or similar)
Alternator Mounting
1.8 Escort Waterpump (runs the otherway round)
Low pressure & high pressure pump, swirlpot, fuel filters
Bellhousing, Type 9 Gearbox (BGH or Quaife)
Waterail (Retro Ford, Raceline Dunnell)
And the list goes on. A blacktop can be had for £200-400 from a breaker or EBay. Jenveys to fit are around £800-£1000 plus the ECU (megasquirt in my case) Wide Band Lamda & loom.
Postby Nash » Tue Apr 13, 2010 11:33 pm
Jeff,
Thats a good list. Is it comprehensive?
If so could you put ballpark costs against them?
..........Neil
Ben_Copeland
Postby Ben_Copeland » Wed Apr 14, 2010 5:45 am
I think the idea of Jeffs post was to highlight that by the time you've finished buying all the bits, its really NOT worth it and you can get a second hand black top and save a lot.... ;)
Ben
Postby jeffw » Wed Apr 14, 2010 6:10 am
I certainly wouldn't buy a new one. If you have a fuel injection tank with a intank pump you can cut out a lot of cost and complexity. The most expensive part will be the gearbox unless you already have a Type 9 from BGH or Quaife. You will certainly need the water pump & alternator fitting kit, shortened sump, Bellhousing, 1.8 Zetec flywheel (4Kg lighter than 2.0lt), 1.8 CVH starter motor. All of this will not come on a crate Zetec. If Zero Cars are providing all of this with the engine and Fuel Injection it is a bargain......
