Car is still at Indulgence so not at the moment. I'll pop into Neaver batteries later and check
.... Neil
Race Battery.
Re: Race Battery.
- Ben_Copeland
Re: Race Battery.
Cheers mate I might even get you to get me one
Ben
Re: Race Battery.
If it's any help I have an Odyssey 680, which is a gel battery (in a hard case before anyone starts the "how do you clamp it down" malarky
) It's about the same size as a car stereo, is easily picked up with one hand & turns the crossflow over easily. Coming back from Stoneliech last year I had a problem with the ignition & the car just stopped every 10 - 20 minutes but would re-start after some cranking. The little battery got me home with no noticable slowing of the starter. Also had a problem with the alternator at Bentley & drove home to Guildford on battery power (can I claim reduced road tax as a "hybrid"). Again no problem.
I was recomended it by a guy with a blacktop Zetec Fury. Apparently the only dissadvantage is they don't like being left discharged so mine's on a "keeper charger" if it's going to be left for more than a week. It cost £90, but it is about 1/3 the weight of a normal battery & can be mounted just about anywhere in the car, anyway up, so the CG stays nice & low.
- Ben_Copeland
Re: Race Battery.
Cool, where did you get it from for £90 ???
Ben
Re: Race Battery.
Is it a motorcycle battery? If so any bike shop should stock them.
...... Neil
...... Neil
Re: Race Battery.
12v 315A (CA) £54.95
mower battery
I'll post a piccy of it later
........ Neil
mower battery
........ Neil
- Ben_Copeland
Re: Race Battery.
I think motorbike batteries aren't any good because they are lot less amps. As the starter motors are smaller.
Had a bike alarm with starter circuit built in and the wires were tiny and you didn't need a relay.
Ben
Re: Race Battery.
Remember,once you start adding headlights,fuel pumps,ecu's,frequent starting and stopping,the alternator won't keep up with the drain of a low capacity battery.An important thing that is offen overlooked is the fuel pump,you need top charge to keep that fuel flowing to those injectors,specially on high performance engines.I can't see the saving of a few kilos is worth the risk of a flat battery.
Re: Race Battery.
Ben_Copeland wrote:Cool, where did you get it from for £90 ???
From here:-
http://www.knightbatteries.com/prodpage ... 08&next=11
Though it was a couple of years ago & they're now £99. It's not a motorcycle battery, though it's recomended for Goldwings & suchlikes. From the bumf on the web site they're a civilian market version of a mil spec battery. I'm not an electrical
After 3 years - two of them testing (with a couple of dead shorts
- Ben_Copeland
Re: Race Battery.
Found a new 680 on eBay for £70 so happy now. Should be fine for what I need it for.
Thanks guys.
Thanks guys.
Ben
Users browsing this forum: No registered users and 37 guests
