Type 9 gearbox rebuild
Green Indy
Re: Type 9 gearbox rebuild
Postby Green Indy » Sat Sep 10, 2016 11:45 am
Hi Andy
Who's your specialist?
My gearbox is coming out on Monday for noisy bearings and I might need someone to rebuild it :(
andyf
Postby andyf » Sat Sep 10, 2016 12:15 pm
It's someone my cousin knows, he used to build gearboxes for the stock cars for years. He's in reading not far from the madjeski stadium. I'll see if I can get his contact details.
Green Indy
Postby Green Indy » Sat Sep 10, 2016 3:03 pm
Thanks Andy
A local garage is going to do the work, but we might need to send the box away for a bit of fettling.
andyf
Postby andyf » Tue Sep 13, 2016 12:15 pm
Green Indy wrote:Thanks Andy
PM Sent
andyf
Postby andyf » Tue Sep 13, 2016 12:16 pm
Got the gearbox back in last night, just need to test it tonight...
Postby Rob E » Wed Sep 14, 2016 9:31 am
andyf wrote:Got the gearbox back in last night, just need to test it tonight...
That'll be good, getting the car on the road, you could do a few runs now.
Postby David T » Wed Sep 14, 2016 12:28 pm
Andy, if you need to do further testing tonight, I will probably be out in the Tiger around dusk.
andyf
Postby andyf » Wed Sep 14, 2016 12:52 pm
We'll be out tonight. I didn't manage to get a run in last night so I'll have to take it easy, at least to start with :) You've got my mobile number, just give me a call when you're heading out.
Postby David T » Wed Sep 14, 2016 2:28 pm
Will do.
andyf
Postby andyf » Fri Sep 16, 2016 12:34 pm
Well the first run didn't go too well, the speedo wasn't working and the clutch cable popped out of the clutch release arm about a mile away from home. Luckily I was able to get home in 4th without stopping! I don't think that I'd engaged the cable correctly in the arm the first time but I still used a strategically placed tie-wrap to prevent it popping out in future. As for the speedo cable, my help mate hadn't located the end of the cable in the drive gear correctly so that was an easy fix. So far the gear changes are all working fine and the nasty noises have gone so I'm keeping my fingers crossed that it will stay that way so I can get out and about :)
