Quick rack?
Re: Quick rack?
All been mentioned really.. got a 2.4 on mine, small steering wheel increases effort especially slow speeds, bump steer is exacerbated if you have alignment issues. Overall worth it.
Re: Quick rack?
Parking my car yesterday, it occurred to me that the Caterham rack might not be as quick as it sounds, because the turning circle is terrible.
Re: Quick rack?
Dick wrote:2.4 is a nice rack to use on the road if you go to low you can find it makes the car very twitchy this is not helped by the way the road surface are . Lots of steering racks have stops fitted in them and people think they have a quick rack because they can only turn it so far.
Can these stops be removed/made better ?? My circle is beyond a joke
- Stevo
Re: Quick rack?
Rob if your car has standard track wishbones you cant remove the lock stops. To do it properly you will need wide track but before doing that check that you have the removable plastic stops.
You need to pull the rack boots back and turn it on full lock to see them each side.
Westfield have in the past used racks with the stops as part of the steering rack casting - hence me saying check.
Team Green now
Re: Quick rack?
How can you tell what ratio you have, if you don't actually know what rack you have?
Re: Quick rack?
ChrisL wrote:How can you tell what ratio you have, if you don't actually know what rack you have?
The 2.4 or 2.9 is the amount of turns of your steering wheel from centre to full lock Chris those are examples obvs
Re: Quick rack?
Cheers rob, so I guess it's dependent on having the lock stops in the right place. Will have a play...
Re: Quick rack?
A quick rack has nothing to do with the stops or how many turnes you have its the ratio of the rack that counts. You could have a standard rack that some one has fitted stops to limiting how many turns you have
So for example you have 3.6 turn rack fitted with stops so you can only turn it 2 turns. This is not a quick rack
Re: Quick rack?
Dick wrote:A quick rack has nothing to do with the stops or how many turnes you have its the ratio of the rack that counts. You could have a standard rack that some one has fitted stops to limiting how many turns you have
Oops, have I been miss leading
- Stevo
Re: Quick rack?
Yes Dick is correct, I should have clarified I was replying to Robs query regarding his poor lock. On a Westie they limit the lock to stop the cycle wings clashing with the bodywork/headlights.
Theoretically you could have a quick rack with lock stops fitted if you had narrow track as it still needs the stops in there to limit the amount of lock as the wings will still clout bits of the car.
Team Green now
