Mitigating loss of oil pressure
Re: Mitigating loss of oil pressure
Postby Dick » Mon Jul 03, 2017 7:35 pm
DJ. wrote:My light flickers at idle after a track session, but I got used to it and can check the gauge if I'm worried.
An oil cooler is your friend
Postby Crunchie Gears » Mon Jul 03, 2017 9:32 pm
I have a 20 lbs pressure warning light on the Westfield just to make feel reassured. Thought I would fit one to the Caterham.
The Morgan has a very low sump and the oil filter sticks out below it so Morgan are making a wooden (I do like a bit of ash) sump guard so the low pressure light is OK.
Gazzawesty15
Postby Gazzawesty15 » Thu Jul 13, 2017 8:47 pm
I did it a few years ago by using a pressure switch to drive a relay which would only engage when pressure was enough to start engine as cranked on starter.. But otherwise a large warning light and a sounder when engine in normal operating conditions.
( I had to make my own PCB with a Mini relay on and an override to ensure the ability to start when needed ) All available RS components.
Gazza
kenton
Postby kenton » Thu Jul 13, 2017 9:14 pm
My ECU wont let the engine fire up until it has oil pressure, usually 5 or 6 seconds cranking. I also have a 20 psi switch that controls a light
ChrisL
Postby ChrisL » Tue Jul 18, 2017 2:29 pm
You could install an override button that you could press when starting (or in the outside lane of the M25)
Postby DJ. » Tue Jul 18, 2017 5:00 pm
ChrisL wrote:You could install an override button that you could press when starting (or in the outside lane of the M25)
Not sure I'd be calm enough to remember that!
