Walkie Talkies in car Radio Again
Re: Walkie Talkies in car Radio Again
Postby Weathers » Fri Mar 13, 2020 1:17 pm
Tony B wrote:dont worry about gardening, we have an entire 2019 season to update everyone on, including the dreaded white butterfly plague on the brassicas last August!
I've missed driving and I've missed the gardening talk...… They say "you need to get out more" and in the case of the kits we are all guilty of that!
Postby Kegco » Fri Mar 13, 2020 2:10 pm
Weathers wrote:Kev. Understandable that they are a tad busy!
What exactly are you trying to do? By scan do you mean look for other “active” frequencies that people are broadcasting on?
Cheers. Chris.
It won’t do anything, matt tried to load SKCC channel, it needs to be defaulted but can’t connect to it
Postby greenwoo » Sat Mar 14, 2020 8:50 am
If it won't connect Kev, have you tried another lead....a lead i had worked fine with 1 radio but not the other, not without a real good wiggle.
Postby Weathers » Sat Mar 14, 2020 10:33 am
Kev I’ve got 4 leads. 1 worked once and never again. 1 didn’t work at all, 1 I haven’t tried yet and 1 works properly but sometimes I have to move USB ports several time depending what mood the lap top is in. Sometimes it’s fine.
I have the default settings saved and I also have the skcc channels. If you can get the radios to me I can probably sort it. Is the ultimate aim to load the SKCC channels?
Postby Kegco » Sat Mar 14, 2020 6:04 pm
greenwoo wrote:If it won't connect Kev, have you tried another lead....a lead i had worked fine with 1 radio but not the other, not without a real good wiggle.
The only thing it’s not the normal lead, you have to screw the connection on
Postby Kegco » Sat Mar 14, 2020 6:07 pm
Weathers wrote:Kev I’ve got 4 leads. 1 worked once and never again. 1 didn’t work at all, 1 I haven’t tried yet and 1 works properly but sometimes I have to move USB ports several time depending what mood the lap top is in. Sometimes it’s fine.
Yeah the ultimate is to load Skcc channel
Cheers there’s no rush next time we’re on the same run I’ll put it in the car
Postby Weathers » Sat Mar 14, 2020 6:54 pm
Cool. No worries.
