Perfect for that sort of thing rich, self isolation, small amount of family balance and hopefully you’ll get a bit of a push on with the build, good luck mate
Can I add I enjoy your vids as well as others so please post some up, cheers
Thanks for the comments and advise one and all
The first coat on the items I have done seemed to go on well enough. Planning to build up with plenty of light layers to avoid runs but it is so easy to want to be a trigger happy painting god when you have a bit of very expensive paint left in the pot that will only go to waste
I am trying to keep the exact colour scheme a proper secret at present so rather hard to do that Rob.
Rob E wrote:Can I add I enjoy your vids as well as others so please post some up, cheers
Well done Rich, looking forward to see what colour and finish you get. Hopefully you can get a good run at the car for a good few days now.
Not another pink car?
wondered why you'd asked Neil for a RAL colour code
greenwoo wrote:I am trying to keep the exact colour scheme a proper secret
If I do organise a day to help me finish it off you all got to wear some blindfolds and work by touch only
Now that I'd like to see!
Bored waiting for paint to flash off before sneaking on a bit more.
Coronavirus won't be getting you in that gear
Well day 2 of the spraying yesterday did not go as well as day 1.
With a full pot of paint I noticed the juddering of the gun and played with the fan and air pressure on the gun to try to overcome it, I did notice that I was struggling to turn the cap on the front to change the fan orientation.
Upon taking the gun apart for the required cleaning after every spray I realised I had not tightened the guts correctly upsetting the air settings.
Days 3, before starting the resultant finish from the previous day was crap as if a reaction to non like chemicals but I decided to leave it as it was the second of the two lighter coats and went for a heavy coat today, hoping that once I give it a while to dry and a light sand to get a decent surface and another decent coat all will be good?
Users browsing this forum: No registered users and 48 guests
