Last night I went out for an early evening run in the Seven with my wife. I did similar roads to Sunday morning.
It was between 7 and 8pm so plenty of light, but there was actually less traffic than 9am Sunday.
So, if you have a kit, but hate getting up early on a Sunday, take it out while everyone is having dinner on a week day evening
Alternative run out time.
Re: Alternative run out time.
An interesting idea - but wasn't it getting a bit cold by then? For me, it would just mean getting really cold waiting for the AA van whereas at least in the morning, it should be getting warmer as I wait
DJ. wrote:Last night I went out for an early evening run in the Seven with my wife. I did similar roads to Sunday morning.
Well done for getting out
But as no photos it didn’t happen
Good idea Duncan, might have to try that shame there's no cafe's open in the evening.
Kegco wrote:Well done for getting out
Good point Kev it must have been a dream
I take it you're still having trouble with your misfire Neil Someone on Lotus 7 forum had a lot of trouble with misfire at high revs. The two solutions suggested were power feed to the ecu and the crankshaft sensor. Good luck finding it.
DJ. wrote:I take it you're still having trouble with your misfire Neil Someone on Lotus 7 forum had a lot of trouble with misfire at high revs. The two solutions suggested were power feed to the ecu and the crankshaft sensor. Good luck finding it.
Ha, no - all sorted (well, I hope). It was the TPS wiring - I'd used crimped spade terminals to add some length and I've come to the conclusion that either my crimping tool is crap or my technique is. Either way, the connection was loose in there - as soon as I took the insulation tape off, 2 of the wires just dropped out the terminals
Soldered them instead now and seems ok so far...
I had a similar problem with my ignition wires a few months ago and that has been OK since I soldered them.
