ok i've been a goon and cooked my battery....so people, what is the consensus from teh great and the good on here?
i fancy a smaller battery like the odessy range, but the cost of those things is harsh......not really into spending mega bucks right now....but by the same token dont wnat a false economy.
so given that we have nothing exact to compare against....what spec should i look for in any battery?
the engibne is high compression albeit with a geared starter and as per most 'kits' minimal electrics......
other consideration is that i'd need to be able to get one delivered puicked up locally for wednesday latest........
so whcih ones, what spec - why?????
Battery
Re: Battery
I have just ordered one off ebay that is half the size and weight of my existing battery 6kg 77mm x 181mm.
I am taking a bit of a punt on this so would not recommended as it is only 20 amps.
Re: Battery
I have one of the Odessy batteries and it is amazing. I kept going through conventional batteries but this is half the size, weight and starts the car first time, every time. Recommended.
Re: Battery
Odyssey seconded. PC680, When I first had the car on the road there was an intermittant fault with the Lumenition "eye" so the engine cut dead about every 15 mins & took anything up to 20 mins to re-start. OK it's only a 50,000 mile Crossflow, but it started it up every time with no problem even after a LOT of cranking. Mine was £90, but I've heard of people getting them for about £70 off Ebay. I put it on a battery keeper when the car's in the garage as the alarm can run it down after a couple of weeks. But it's been on the car for three years now with no probs at all, the first of those three years was while I was wiring the car up, so it survived the occasional dead short .
I've also heard that the PC680 it the Ultima factory fit for all the engines they use.
Have a look here http://knightbatteries.com/home.cfm
Failing that, how about a bike battery for one of the bigger BMW bikes? can't imaging they take chances with capacity.
T
T
- Contaminated
Re: Battery
Mark, i went the conventional way, fitted the biggest bad boy lead acid battery that i could fit in the space.
1oo Amp hrs
900 CCA
Marine Diesel engine start Battery.
1oo Amp hrs
900 CCA
Re: Battery
I went with this one http://www.powervampracing.com/detail.asp?ID=24
It has a huge reserve of power, its the same battery they fit in their portable grid start power packs. They do smaller ones
suitable for cars with fewer cylinders.
kenton
kenton
Re: Battery
Have just put the new RMD 25 on charge will let you know how i get on should be good as it is Rally Design.
Re: Battery
Nogoingback wrote:Have just put the new RMD 25 on charge will let you know how i get on should be good as it is Rally Design.
"Two aviation specification versions of this battery were used on the Harrier VTO aircraft to start the Rolls Royce Pegasus engines."
Not much of an achievement as a jet engine has no compression (stationary) & they have to put a bungie round the fan blades to stop any slight breeze spinning the engine up. I think I'm right in saying that only one is used to start the pegasus, the other is a spare.
T
