Tony B wrote:ChrisL wrote: Thinking Steve RST but he's probably busy doing the Setimolod '17 video!
You've got more chance of your car being completely finished, RRed and a few thousand test miles on the clock
He's probably right
Sounds like a great project Chris. Get the plenum work-in-progress pics up!
I recently re-did all my fuel lines in 8mm ID for both supply and return. That'll flow plenty of fuel in an EFI system and, from what I read, most suggest running the same diameter for return. Fuel hose you want to cope with increasing ethanol in petrol is spec'd as SAE30 R9. Google it and people talk of lots of fake hose around though.
My experience of Megasquirt has been pretty good. I ordered it to suit my engine... zetec running standard (twin) coilpack, wasted spark setup so not using a cam sensor. Engine position is determined using a standard Zetec crank position (VR) sensor and the zetec flywheel which has the 36-1 trigger designed in to it, so no need for a different trigger wheel.
Wiring it up involved extending the basic MS loom and soldering suitable connectors. Checking and double checking. My engine started up ok. In fact I was kinda amazed that it just ran... maybe I was particularly luck. Took quite a while to get it to idle reasonably. Then multiple times tweaking the maps and tables, buy that's parr of the fun and learning process.
I like the MS tunerstudio software and autotune works great. My car been spanked for 4 years now without issue - lots of track days and trips abroad and never been on a rolling road or tuned by anyone else.
I did have trouble with getting the ECU to control the cooling fan. I've never been able to get this to work. Configuring inputs/outputs like that is complicated I think because it likely would need changes to hardware rather than just software? Not sure, I gave up on that.
I am a little concerned that the MS ecu doesn't look very 'durable'... i mean in terms of moisture ingress, shock proofing, etc. All a bit 'home-made' in that respect... which i guess was the original idea to be fair.
What's the price difference compared to OMEX etc? Why not MS3 rather than MS2? Ive read good feedback on ME221 ecu which may be another cheaper option. Popular with the MX5 turbo lot.
