Viento Project
kenton
Re: Viento Project
Postby kenton » Wed Aug 31, 2016 7:33 pm
Just caught up with this thread, sorry to hear of your troubles Mike. Out of interest, what front cover does the 4.6 use? I may be interested in buying some of bits from you.
Re: Viento Project
Postby b33fy » Wed Aug 31, 2016 7:43 pm
Hi Kenton, no worries mate, goes with the territory. She gonna fly with the new engine.. :lol: The oil pump is totally different on the 4.6, driven direct off the crank, so no good to you.
New mount for crank sensor done, pulley needs cleaning up and a bit of paint
New coil pack mount made and fitted
Overall view of new engine in situ, looks much the same as the last one, though hopefully will run better.
The 3.9 oil pump arrangement won't quite clear the chassis so need to pull apart the old oil pump and see what mess is inside and sort it out.
kenton
Re: Viento Project
Postby kenton » Wed Aug 31, 2016 7:53 pm
V Nice 8-)
Be interesting to see how yours compares to mine when/if you get it mapped as I have a very mild cam.
I'm still using the 3.5 front cover with the oil pump driven off the cam shaft.
What coil packs are those? not the usual ford ones.
Re: Viento Project
Postby b33fy » Wed Aug 31, 2016 8:26 pm
kenton wrote:V Nice 8-)
You are welcome to the front cover if it's any good to you, can't vouch for the condition, personally I wouldn't use it, as the oil pressure isn't good. The heads, pistons (brand new) and ARP conrod bolts are the only things I would bother with from the engine.
Not expecting anymore than around 210/215bhp if everything is perfect. The coil packs are VW jobbies which have their own built in igniters rather than the separate EDIS system of the fords which most seem to use. They work rather well and kick out a hefty spark.
Re: Viento Projectz
Postby b33fy » Thu Sep 01, 2016 8:44 pm
Left to do.. Fit up the oil pump and cover plate, bleed the clutch and hopefully fire it up. Some issues with the relief valve, sticking half open, doesn't really explain the symptoms, as it was sticking closed on start up. Like a baby's rattle now,, without the spring fitted..
Re: Viento Project
Postby b33fy » Sat Sep 03, 2016 8:03 pm
Huge thanks to Jay for a helping hand this afternoon, the good news is.. it's running.
Re: Viento Project
Postby DJ. » Sat Sep 03, 2016 8:13 pm
Very glad to hear it :D
Re: Viento Project
Postby b33fy » Sun Sep 04, 2016 8:16 pm
Thanks Duncan, the oil pressure still proved a little elusive, sorted today, caused by the mocal take off plate which is now in the bin. Oil pressure solid at 30psi tickover, 60psi at 3000+rpm with engine hot. the relief valve cuts in now as it should keeping the oil pressure to 60psi.
Took it for a quick spin, very smooth, doesn't vibrate like the last one so I can see where I'm going over 60mph lol, lost a lambda and still no electricity, who cares.. the oil pressure is finally sorted lol.
Re: Viento Project
Postby Tony C » Sun Sep 04, 2016 9:14 pm
Well done Mike and Jay, good to hear its all sorted now, time to get out and enjoy driving it, and it only took 42 pages.......Always had a hankering for a V8, perhaps in the next car?
Re: Viento Project
Postby steve m » Sun Sep 04, 2016 9:33 pm
Tony
A Rover V8 does fit in a Midget/sprite, just !
Users browsing this forum: No registered users and 50 guests
