Phoenix fettling
Re: Phoenix fettling
Postby Matth93 » Sun May 15, 2016 11:24 am
jeffw wrote:now that is has been run in (!)
Our race cars used to get run in on the track a bit like that. They got the practise session on the day we were racing :lol:
Good to hear it's all back up and running now as dick says time to start winning
Postby jeffw » Sun May 15, 2016 8:17 pm
Paddleshift test on the Phoenix
https://youtu.be/P1t44TQG_Yw
Postby Nash » Mon May 16, 2016 8:10 pm
Any footage from Llandow Jeff
Postby jeffw » Mon May 16, 2016 9:02 pm
Sadly no, I spent all my time getting the car working and didn't have a chance to set the Video 4 up again. I'll get it running this week and might take a run out in the car before Snetterton to check everything is OK.
Postby jeffw » Mon May 16, 2016 9:06 pm
Postby Nash » Tue May 17, 2016 5:16 am
So, first impressions of the paddle shift?
Postby jeffw » Tue May 17, 2016 5:48 am
It is very intuitive, never even thought about reaching for a gear lever. It is very fast to change gear and it is a little bizarre not to have to use the clutch at all (apart from moving away or coming to a halt). You can change gear in corners without unloading the transmission and upsetting the car so you can certainly take liberties compared with a conventional H pattern box. Braking is much easier as there is no heel/toe required do you just plant your foot on the pedal, I suspect I'll end up left foot braking as this will allow me to trail brake easier and have faster transitions from accelerating and braking.
I knocked it out of reverse a couple of times while manoeuvring which is something to watch and the paddles move with the wheel so it takes a moment to work out which is up or down to get it back into reverse gear.
The interlock to go from neutral to first/first to neutral with the need to use two buttons is essential or you would find that you'd gone from 6th to Reverse very quickly (with the expected consequences!).
The air pump is very loud when you first put the power on, it sits at 180psi on the accumulator so the pump is on until that pressure is reached and then comes back on when the pressure dips below 150psi.
Postby jeffw » Tue May 17, 2016 5:53 am
andyf
Postby andyf » Tue May 17, 2016 6:38 am
A bit like driving a gearbox kart, great fun :D
Postby Crunchie Gears » Tue May 17, 2016 10:43 pm
I still have not got the hang of paddles but have only used them on other peoples cars. That said I like that you are enjoying the change in drive styles too. I wish you well in your sprints with the new setup Jeff. :D :D
