Brake pipe flaring tool
kenton
Postby kenton » Fri Feb 22, 2019 8:37 pm
Evening all.
As part of re building my car I'm going to replace the brake lines. One of the original pipes is damaged and the the others don't always follow the best route.
I've had a couple of the cheap sub £20 tools and they are rubbish, the castings break or the threads go.
Unless anyone local to me has one I could borrow next week I was going to buy a new quality tool.
Any sugestions?
Something like this
https://www.ebay.co.uk/itm/BRAKE-PIPE-F ... 0005.m1851
What do you all use??
K
nelmo
Re: Brake pipe flaring tool
Postby nelmo » Fri Feb 22, 2019 9:25 pm
I'm sure that one is good (better be for that price) but I used this one very successfully:
https://www.ebay.co.uk/itm/Brake-Pipe-F ... ect=mobile
Postby locost220 » Fri Feb 22, 2019 9:27 pm
That the better type of the two I have Kenton.
Happy for you to lend it but a fair way from you.
I am off the the race retro show at stoneleigh if any local to you are going
Or couldd maybe get it to Matt Saturday if he going near you soon.
Postby b33fy » Fri Feb 22, 2019 9:38 pm
I've used the cheaper tools previously, they are a bit hit and miss.. imo the trick is a clean cut with a pipe cutter and set the pipe in at the correct length, also make sure its de-burred. A bit of lube helps. :? :D
A bit loathe to buy the dearer tools as I dont really do enough to warrant the cost.
kenton
Postby kenton » Fri Feb 22, 2019 9:44 pm
Thanks guys.
Rich, thanks for the offer to use yours, A bit too far away and hassle for a relay.
I like the price of this one better and as its only got to do a dozen ends...
nelmo wrote:I'm sure that one is good (better be for that price) but I used this one very successfully:
Mike, everything is better with lube...... :?
