Mixed weather conditions, I was 4th fastest in T1 (very wet), 6th in T2 (less wet) and ended up 8th in the top 12 Runoffs (best result so far).
T1 wet run
https://www.youtube.com/watch?v=MHmYtFC40k0
External view
https://www.youtube.com/watch?v=lCJlLFAEPY0
Fast run in the Runoffs
https://www.youtube.com/watch?v=S15P1-gVLY4
British Sprint Championship - Pembrey 2nd June
Re: British Sprint Championship - Pembrey 2nd June
The first wet run looks pretty scary Jeff.
Running full Pirelli Wets so surprisingly calm behind on the wheel...that was good enough for 4th overall in T1
Looked good. To me it looked like it struggles on the pull away a little does that affect your time or is it once you cross the start line?
I have a problem operating the clutch. I realised why at Pembrey, basically my seating position is wrong. I'm currently too high in the car with straight legs, need a new seat so my head is lower and my legs are bent (and supported). This will allow me to use the clutch correctly and be more comfortable in the car.
Those wets look very good. I noticed you were the only one running them on the leader board? What are the others running?
Avons or circuit wets. There where others on Pirelli wets as well.
