hi all
Steve j
hi all
Postby Steve j » Tue Jun 25, 2019 8:28 pm
after meeting tony t at bromley pageant at the weekend i thought i would join up and say hi.
im steve jenner and have built a couple of roof chopped minis in the past but have never owned a kitcar and thought it was about time to try and build a car from scratch.
i started my project last september and have got a long journey ahead.
in short its a one off chassis looking a bit like a arial atom but its a single seater with a subaru impreza engine mounted in the back, haynes roadster suspension geometry and mx5 uprights and brakes.
thanks in advance for all the pis and advise ill be asking you guys for
Re: hi all
Postby locost220 » Tue Jun 25, 2019 8:36 pm
Looks brilliant, welcome to the club.
SJLB
Re: hi all
Postby SJLB » Tue Jun 25, 2019 8:37 pm
welcome to SKCC, it looks like a great project you've got there.
SteveRST
Re: hi all
Postby SteveRST » Tue Jun 25, 2019 8:46 pm
Wow, that does look really good! Welcome to the forum.
Be great to see a full build thread on this project.
Re: hi all
Postby Wingco » Tue Jun 25, 2019 8:51 pm
Hi Steve, welcome to the best kit car around. You certainly got your hands full on that project, there are plenty of very helpful people on here, but it will come with a lot of piss taking.
Crack on Steve and keep us updated
Re: hi all
Postby greenwoo » Tue Jun 25, 2019 9:05 pm
welcome Steve.....one heck of a project, but looks as though you enjoy a challenge..
Re: hi all
Postby Matth93 » Tue Jun 25, 2019 9:17 pm
Welcome to the club.
The build looks interesting, it'll be nice to see how it comes along
Re: hi all
Postby b33fy » Tue Jun 25, 2019 9:29 pm
Welcome, interesting project there, a few challenges ahead no doubt. I’ve had previous with a scooby engined V-Storm, cooling and gear change being the two biggest head aches.
Steve j
Re: hi all
Postby Steve j » Tue Jun 25, 2019 9:44 pm
b33fy wrote:Welcome, interesting project there, a few challenges ahead no doubt. I’ve had previous with a scooby engined V-Storm, cooling and gear change being the two biggest head aches.
thanks all for the possative comments.
as far as the gear linkage ive used a modified mr2 gear leaver with mgtf cables and a custom linkage. it seams to work ok so far but please let me know if you see any problems with it.
what problems did u have with the cooling system.
Re: hi all
Postby b33fy » Tue Jun 25, 2019 10:57 pm
Pretty similar solution to mine, below..
Radiators were marginal especially rear mounted facing towards the back. Looks like your engine is NA if the coolant system is routed the same as the turbo lump you need to make sure you get some coolant to the cold side of the thermostat. I guess you’re not running a heater so connect the two ends of the pipes together to complete the circuit and ensure some hot coolant gets to the cold side otherwise the thermostat won’t operate properly. Or remove water pump impeller and thermostat and run an electric water pump.
