Welcome on board Steve,
All the best with your project. Keep the update and pictures coming, looking good so far
Kev
7oaks
hi all
Re: hi all
Re: hi all
Hello Steve and welcome to the club. That's a nice looking chassis.
As said elsewhere a build thread would be of interest to a lot of us.
Once again welcome
Neil
Once again welcome
Neil
Re: hi all
Welcome to SKCC, I look forward to seeing your car progress
Not sure it really is a kit car, more of a one off prototype! You might have to start selling kits later on when people see you driving it, because it looks great so far.
Duncan
Duncan
Re: hi all
b33fy wrote:Pretty similar solution to mine, below..
Radiators were marginal especially rear mounted facing towards the back. Looks like your engine is NA if the coolant system is routed the same as the turbo lump you need to make sure you get some coolant to the cold side of the thermostat. I guess you’re not running a heater so connect the two ends of the pipes together to complete the circuit and ensure some hot coolant gets to the cold side otherwise the thermostat won’t operate properly. Or remove water pump impeller and thermostat and run an electric water pump.
yes its a na quad cam engine. i was planning to join the 2 heater hoses together but have recently been thinking of blanking them off then remove the thermostate but keep the standard pump. will this be ok ?. im planning to fit the rad up front in the nose sloping back but as u can see there isnt much space. do u know what rad u used and the sizes of it as i would prefur to use one from another car than to have a custom one made. do u know anyone in kent that can do ecu work as i need the secondary air delete.
thanks
Re: hi all
DJ. wrote:Welcome to SKCC, I look forward to seeing your car progress
Duncan
thanks duncan
sorry im a bit new to forums. where on this site would be the best place to start a build thread
Re: hi all
I would put it
in General gassing/ Car related discussion,............... but I have been known to be wrong
Re: hi all
Steve j wrote:b33fy wrote:Pretty similar solution to mine, below..
thanks
Re: hi all
Holy Moly!!! Thats amazing! Welcome aboard.
- Tony T
Re: hi all
Alo mate welcome this is the place to be
Tony T
Tony T
Users browsing this forum: No registered users and 48 guests
