The Exocet has started making a weird noise coming from the drivers side rear wheel. I its like a rotational rub or creak once per rotation, seems to be there all the time but is more noticeable at slow speed under gentle braking. I've whipped the wheel off to take a look but just cant work it out and its not a trapped stone.
Wheel bearings are good, discs and pads were brand new on the build so Im hoping it hasnt warped.
Any ideas guys as its bloody annoying.
Cheers
Weird noise, brakes?
- andyf
Re: Weird noise, brakes?
It's not the tire rubbing on the bodywork somewhere?
andyf wrote:It's not the tire rubbing on the bodywork somewhere?
Nah checked that mate
When I have had this in the past it was a loose wheel (knock on Lotus Elan ) and then a warped disc. If it is the disc, you would feel vibration when breaking.
Duncan
Duncan
DJ. wrote: If it is the disc, you would feel vibration when breaking.
Duncan
Thats what I thought mate
Drive shaft CV joint problem?
DJ. wrote:Drive shaft CV joint problem?
Could be
- Flyingtiger
Flyingtiger wrote:Just keep the revs up, can't hear it then ...
Nah I want to sort, have ordered a 2nd hand and tested driveshaft
Users browsing this forum: No registered users and 48 guests
