Today’s break down
Re: Today’s break down
Postby Kegco » Mon Sep 30, 2019 5:01 pm
graham b wrote:Well done .
Run sunday ??
Or are you going on holiday
:D
Think I’ll have to check my holiday diary :lol:
Postby Wingco » Mon Sep 30, 2019 5:28 pm
Nice one Kev
Postby b33fy » Mon Sep 30, 2019 5:40 pm
Good work Kev, hope Matt kept an eye on you! :lol:
Postby Matth93 » Mon Sep 30, 2019 6:40 pm
No I wasn’t there but it had been started before he picked it up
https://youtu.be/xHLyruGZr7w
Postby Kegco » Tue Oct 08, 2019 12:55 pm
Saturday afternoon drove the tiger ST to Matt’s for a bit of a tune. As it was running a bit lumpy and the clutch was high and slipping.
Changed the plugs and put a different map on the car. The engine was running well, no flat spots/ leaks. So all good.
Tried to adjust clutch but was getting worse, thought it might of been a greasy/oily clutch due to the bottom end failure.Which means engine out again! But thought we would try a shorter clutch cable as I still had the cosworth cable, that wraps around the car twice.
Sunday went to my handy motor shop and picked up a Sierra clutch cable, fitted it, but still slipping. Spoke to Matt and he looked into it and found out that they do 2 different size clutch self adjusting quadrants 45 and 55 and I had the 45.
Matt got me the 55 which would give me more adjustment.
Today just so happens that Matt and I both had a late start, so he popped over with my part and we fitted It, which wasn’t that easy to strip out and refit. Ended up getting the welder out, and welded a couple of nuts to make it easier in the future.
Took it for a spin around the block and looks like it solved the slipping clutch.
Just need to get some miles down know
Thanks again Matt https://youtu.be/v2CIatA9PlI
Postby Wingco » Sat Oct 12, 2019 7:08 am
Sounded good Kev, glad you are now sorted and back on the road.
Users browsing this forum: No registered users and 51 guests
