Hi all.
Jasonmpk
Re: Hi all.
Postby Jasonmpk » Mon Jun 22, 2020 6:22 pm
Hi all, Many thanks for all your replies. Have gotten to the last bits before an IVA i hope, just need to sort a rear boot cover and finally decide if i should re design my tunnel cover and gear stick gaiter, am not totally happy with it seeing as it's about 14 years old and probably in need of a rethink.
Jasonmpk
Re: Hi all.
Postby Jasonmpk » Fri Jul 03, 2020 9:39 pm
A few more pics.
Rosbergg21
Re: Hi all.
Postby Rosbergg21 » Sun Jul 05, 2020 12:28 pm
Welcome to Skcc
I’m in Croydon too, hope to see you all soon.
Re: Hi all.
Postby Nash » Fri Jul 10, 2020 7:22 pm
welcome to the club. 14 years is a labour of love and dedication.
Good luck with the IVA
Jasonmpk
Re: Hi all.
Postby Jasonmpk » Sat Jul 11, 2020 10:28 am
Cheers guys, Even with a 10 year hiatus it's still a long build :D
I think I only have to sort out the bike carbs, install rubber soft trim to my f/glass seats, fit an IVA compliant relay set up from CBS to make my fog light switch new IVA compliant and cover my steering column to hide the std switch cabling.
So by the time i receive a reply from the DVLA about a chassis number, I can then start the IVA application.
I can't wait to drive it on the roads
Jason
Jasonmpk
Re: Hi all.
Postby Jasonmpk » Sun Aug 02, 2020 7:46 pm
Hi all, well just an update. I took the car for a fill up with fuel and drove it to my local mot guy to get the chassis plate welded in. when i got to him i found out that i had a petrol tank leak so had to drain out what was left so that the welding could carry on. Got it back home and tried to strip out the tank, but it wouldn't come out so just managed to get to the offending cover plate and strip that off too, cleaned it all up and resealed it and all seams good now. So that was refitted, and moved onto the lack of caster angle.
Found about 3mm of movement on the top wish bones which when rebuilt and test driven it felt so much better i couldn't stop smiling. It still isn't enough for the IVA test, so I'll be doing the same on the lower wishbones and moving them forward by hopefully the same 3mm.
The trials of building a kit car eh !!!
Jason
Re: Hi all.
Postby DJ. » Sun Aug 02, 2020 7:57 pm
Better to find these problems before IVA, sounds like you're making progress :)
Re: Hi all.
Postby locost220 » Sun Aug 02, 2020 8:17 pm
Many of us have been en there Jason, keep at it the rewards will be well worth it.
Jasonmpk
Re: Hi all.
Postby Jasonmpk » Mon Aug 24, 2020 6:39 pm
Just an update on the progress and look of my locost.
Jason
Re: Hi all.
Postby DJ. » Mon Aug 24, 2020 7:52 pm
Looking good, I like the wheels :)
Users browsing this forum: No registered users and 37 guests
