Following an engine conversion, we have the following x-flow parts for sale:
4 into 1 Terry Nightingale Mild Steal Exhaust manifold £125
Twin 45 carb inlet manifold £40
Alternator x 2 £50 each
Caterham Shallow Sump & oil pick up pipe £100
Rob Morely bottom end (requires a rebore and new pistons) Make me an offer
244 cam £50
Single 45 Dellorto Carb on Lynx Manifold £125 - Sold
K&N Air Filters 63mm £5 (83mm sold)
Type 9 Bell housing and CRA £10
I can arrange postage for all of the above (except the Bottom End).
Pete
X-flow bits for sale
Re: X-flow bits for sale
Hi Pete,
Can I have first dibs on the K&N's please. But before I commit to buy I need to ask the following:
Are the K&N's socks? If yes does it mean that you have three when four are needed for a complete fitment?
If these are not socks then can you elaborate please?
I do need to filter all the horns. (Suppose it goes without saying).
No they are cotton filters with Stainless Steal front and back plates like this:
http://www.burtonpower.com/parts-by-fitment-type/parts-by-carburettor-all/kn56-1170.html
Two are 83mm and one is 60mm I think (I will double check tomorrow), one (as pictured) will cover one twin carb.
HTH
Pete
HTH
Pete
Hi Pete, interested in the bottom end , as it been overbored already or is it standard ?? are you at north weald next w/e or the w/e after ,cheers Pete D
Yes, I'm over at North Weald on 13th March, but I based in Chelmsford - not a million miles away.
The block has been bored to 1700cc 83.5mm pistons and has been inspected and confirmed that it can take the next size up but it will take it over 1700cc. I will try and did out some pictures for you.
Pete
Pete
Here you go.
Damage here:
Please note the sump and engine mounts are available separately.
Damage here:
Pete, mind sound a bit daft ,but does it include crank ,rods ,caps. if the single kn is 65 mm i'll have it pls. cheerd Pete D
Yep, includes crank, flywheel, clutch cover all lightened and balanced, all rods and caps. Also includes various tensioner and bits from inside but everything is stripped down.
Doesn't include sump, mounts, cam, duplex timing wheel and chain.
I don't think I can take it to North Weald as we have quite a log of gear already for sprinting and not much room. Not looking for a hugh amount for it, was originally up for £50.
HTH
Pete
HTH
Pete
Pete,
Sorry these filters will not fit under my bonnet (Tried some before).
Its all to do with cutting a hole in the side of the bonnet and the forward bonnet clip being in the way etc.
So its down to a second dibber now then.
Thanks anyway
Ian
Thanks anyway
Ian
