Brand new, never fitted, Wossner Hi-Comp pistons. These are the 85.5mm version which will need the stock cylinder to be bored. They have bigger small end bearings than stock so need forged rods.
More info of the specific model here
http://www.performanceenginecomponents. ... ?id=250561
Retail is £560 inc, these are for sale at £350.
Wossner Zetec Pistons
- zxr400
Re: Wossner Zetec Pistons
if you are fitting a blower,would you not need lower comp pistons,or is that depending on what boost you run,on the wscc they say you need 20hp to run a blower so to make it all worth while seems big upgrades are a must,
These are high compression pistons (12.5:1) for tuning NA engines. If they where low-compression I would keep them for the supercharger conversion.
- zxr400
arr with you jeff,
- zxr400
once jeffs sorted all the problems,
but to be honest the car is fast enough,I'll only break something
