hi to all..Searching for good advice!!!
Hi to all at the club, would love to get a runout with you some time,not to easy being from West Wales, but i joined because after reading alot of forums this was head and shoulders above any other, everybody seems very helpful and there are loads of bits on offer.....Built a few Escorts in the past for rallying, this was my first venture into kit cars...Have a Locost with a suzuki GSXR1000 engine /box, ajustable suspension etc..all very well preped and built although not by me, i would like to step it up a bit now and just bought a cossie 3.62 lsd and want to change the xr4i drum set up for discs...Without stripping everything and measuring will the discbrake hub bolt onto the locost drum hub carrier, i can fabricate a new bracket for the caliper if none are available but are the bolt holes common size for disc or drum...any advice will be great.......top club.
Re: hi to all..Searching for good advice!!!
welcome, well the 1st bit of advice is to leave the mods til the winter and come up to llandrondid and join us for a bit of blatting on the 5/6th may!
as to teh real answer - can;t help - maybe Dick or someone else with the required knowledge can help........
Hi Mark and welcome.
I have the same set up as you at the back and as I understand it it isn't a direct swap. I do believe Rally Design do a conversion kit but wouldn't swear to it on the bible?!
Hope to see you in Wales 5/6th May when we drift into Wales on the Road trip.
Once again welcome.
...............Neil
Once again welcome.
...............Neil
hallf12 wrote:......any advice will be great
Welcome indeed, & like was just said, come & see us next week. 'Fraid I can't help with the spacifics, other than to ask if the rear discs are going to be worthwhile. I have Sierra 9" drums on the back of the Fury & have half-heartedly been looking to go down to 8" drums. The 9" were used on the back of Transits, so are over-speced for a kit car So I thought the reduction in unsprung weight would be more benificial. Just my opinion of course - I do like to play Devil's advocaat
Hi and welcome, as others have said hope to see you on the 5th/6th May
It would be good to see you when we're in Wales. As for the discs, they undoubtedly look better, but I'm with Fury1630, you don't need the stopping power of discs at the rear, so you'll need to add some form of compensator to reduce the braking force at the rear to something similar.........to drum brakes
Hello and welcome
There's a lot to be said for drums on a very light car like yours.
If you are happy with the balance at the moment it might be better to stick with them.
Duncan
Duncan
Welcome.
I've got non vented discs at the front and drums at the back. Seems to have plenty of stopping power and easy to lock the wheels.
Rear discs look cooler of course, but they can be tricky to get through IVA, even with a proportioning valve.
Hi Mark & welcome.
I run a BEC MAC#1 GSX1300R Hayabusa with Disc's all round, The rear has sierra hubs drum Type with brackets and mounting for wilwood calipers and ford escort disc's Mac#1 made them for me they should be able to help.
Mark at MAC#1 is a great help and should be able to sort things out and if not will now who can.
Marks No 07961324235
Hope to see you soon
Phil
Phil
- zxr400
hi mark we are doing a blat to wales 8,9 June and on the 15 16 17 June to,like wales nice people and great roads p.m me if you want to join us you are most welcome,ho and welcome to the club
