WTD wideband kit
WTD wideband kit
As above, anyone got a kit kicking around they want to sell, Emerald have recommended either the techedge or AEM but i guess innovate will do to, i want the complete kit including a guage
Re: WTD wideband kit
Where are you going for the remap? or are you going to have a go yourself?
Im likely to try these guys out..
http://www.dyno-solutions.co.uk/#/rolli ... 4534805273
I know someone who has used them and he runs an emerald
I think they are the guys that Dave Walker has recommended as an altenative Emerald mapping centre, id rather not travel up to Dave again if i dont have to.
When do you reckon youll be ready?, arent you going for a full rebuild first?, mine will be toeards the end of Feb with a bit of luck
, ill see if i can do a deal if your up for it, i think Alan (banbury) is also using these guys!
I want a wideband as i want to set tge ecu to adaptive mode, and to check if it suddenly goes off tune
Ill probably just go for one of these
http://www.ebay.co.uk/itm/AEM-GAUGE-6-i ... 45f47956b6
I assume theyll do the same job as any of the other makes.
Wheres Jeff, he's normally got something like this in his garage he wants to sell
Engine out end jan, full rebuild. Rebuild of twin throttle plenum with conversion to center pull.
Gearbox too as selecting can sometimes be problematic.
Back in end feb
(but dont hold me to it ).
So yes a group deal may be available, your good at that
Back in end feb
Ok, ill make the preliminary call tomorrow and sound them out
Matt, are you happy with it?, and is it a solid bit of kit?, im always concerned in buying one of the cheapest ones from the bay, the concern is the output that feeds into the ecu doesnt read right!
yep,seems a good bit of kit,the voltage output range was wrong for my ecu,(so check that)but i only use it for indication only.I ended up buying a different lamda to suit my ecu in the end.
daxmatt wrote:yep,seems a good bit of kit,the voltage output range was wrong for my ecu,(so check that)but i only use it for indication only.I ended up buying a different lamda to suit my ecu in the end.
Ahh, how do i check it?, it says 0 -5v output which i think is ok for the emerald, or is it a different voltage?
yep ,its what it says on the tin,the 0-5 was right.
I can't remember what my ecu was now ,but lets say it needed to be betweenwas 0-9 volts
