Ford type 9 gearbox with Quaife gearset
Kaivaksdal
Postby Kaivaksdal » Fri Nov 06, 2015 5:01 pm
Hi everyone
After a few niggles with the synchro rings, I've decided to buy a brand new built SPC gearbox for the Tiger Super Six.
That means my old Type 9 gearbox with Quaife gearset and long 1st gear will be for sale.
Gearbox has done less than 2000 miles since the Quaife gears were fitted and only 500 miles since last rebuild (replaced all synchro rings).
It works perfectly up the gears but occasionally doesn't like 4th to 3rd. It's easy to drive round, but could mean another synchro - they're £18 new from Ford or Burton.
I genuinely think that this gearbox would suit a Pinto or Zetec engine perhaps with a bit less than my 210bhp but it's been fine up til now (synchro rings aside).
It's Quaife internals are very strong, I think it's semi-helical as it whines a little but not like straight cut.
Not sure of the ratios but long 1st, 1:1 in 4th and 5000 rpm at a true 115mph if that helps.
I'm thinking it's worth £500+ but let me know your thoughts on it.
Gearbox should be coming out in next 2 weeks so no rush. I'll do some photos when it's out.
Regards
Kai
ggdrew
Re: Ford type 9 gearbox with Quaife gearset
Postby ggdrew » Thu Nov 26, 2015 12:25 pm
Hi Kai,
Please drop me a message via the board... I need to know where you are for a start, and then I'd like to talk to you.
Thanks and best regards / Gary
Kaivaksdal
Postby Kaivaksdal » Thu Jan 21, 2016 6:00 pm
Just to let you all know, the new gearbox is being fitted on February 2st so my old gearbox will be available from then.
Gary and anyone else please let me know if you're interested.
Thanks
Kai
Kaivaksdal
Postby Kaivaksdal » Wed Feb 24, 2016 2:49 pm
Hi everyone. Finally the old gearbox is out and the new SPC one is in. This means that my Type9 Ford 5 speed gearbox with full Quaife gearsets is now available. Email me at [email protected] and I'll send pictures and try to answer any questions.
Thanks.
Kaivaksdal
Postby Kaivaksdal » Fri Mar 04, 2016 12:26 pm
Just a quick note from me to say please contact me if you're interested as I'll be putting it up on EBay on Sunday.
Cheers
Kai
Kaivaksdal
Postby Kaivaksdal » Thu Mar 17, 2016 9:38 am
Sold
