car storage rack
Dave Z
car storage rack
Postby Dave Z » Sun Nov 22, 2015 7:57 pm
hi all
Looking for some advice from some one with steel structural knowledge.
I am short of space in my garage and want to make a rack so that I can store my trials car which is 500kg above my autotest car.
I am looking at two steel beams supported at a max of 4m apart, the beams will be 1m apart.
what size should I be looking to use?
thanks
Dave
bigstuff
Re: car storage rack
Postby bigstuff » Sun Nov 22, 2015 8:09 pm
Dexion ? :?
Dave Z
Postby Dave Z » Sun Nov 22, 2015 8:21 pm
Ihat will be too light I think,
I need a clear space underneath which needs to be 3.4 m minimum, so with the supports etc will be about 4m span.
andyf
Postby andyf » Sun Nov 22, 2015 8:30 pm
How are you planning to get it up there Dave?
Dave Z
Postby Dave Z » Sun Nov 22, 2015 8:42 pm
I have a 1 tonne forklift loader to lift it on
Postby steve m » Mon Nov 23, 2015 8:13 am
If I had the height and a garage large enough to do it, a two post lift ?
that way you would have something useful for your other cars as well
there's a few on ebay, but for some reason I am unable to attach any links ?
Postby Rob E » Mon Nov 23, 2015 8:57 am
If your talking about I beams then I'd get some calcs done,not something you could just guess.
Dave Z
Postby Dave Z » Mon Nov 23, 2015 10:33 am
Rob E wrote:If your talking about I beams then I'd get some calcs done,not something you could just guess.
Thats what i was hoping for from here from some clever people.
[quote="steve m"]If I had the height and a garage large enough to do it, a two post lift ?
I havent got the height for a two post lift either, did consider lifting the roof but suspect planning might be a problem.
kenton
Postby kenton » Mon Nov 23, 2015 1:21 pm
I would guess but thats just me. I'd rather pay for a larger steel that someone to work out the min required.
Go for what looks right, then get the next size up. :roll: 245, 135 35kg ?
Mel T
Postby Mel T » Mon Nov 23, 2015 1:37 pm
