A little bit of Aero
Postby jeffw » Thu Jun 16, 2016 9:39 pm
Does you good...at least that is the plan
Re: A little bit of Aero
Postby Dick » Fri Jun 17, 2016 6:55 am
Tidy looking lets hope you get some benefit from it. Not carbon then :lol:
Postby jeffw » Fri Jun 17, 2016 7:03 am
Not yet....lets see if it all works before we get to the carbon stage ;)
Postby Dick » Fri Jun 17, 2016 7:42 am
Is the bonnet hinge working ok ? I would stay with plywood and carry the weight penalty of it as its cheaper to replace they all ways get damaged somehow
Postby jeffw » Fri Jun 17, 2016 7:47 am
The bonnet hinge works to a point. There is a lot of intercooler mounts etc which get in the way and it doesn't lift as high as I'd like at the moment. Might need to a little fettling....
Postby Dick » Fri Jun 17, 2016 7:52 am
So when you testing it then ?
Postby greenwoo » Fri Jun 17, 2016 8:26 am
adds to the overall look.....
i see that you had the lappie out to do the calculations for the splitter & diffuser :lol: :lol:
Postby jeffw » Fri Jun 17, 2016 9:58 am
I'm off for a double header at Blyton this weekend and then Debden in Essex next week.
The lappie is out to change the config on the Gearbox control unit, the FTG settings on the ECU and the launch control rpm setting on the Traction system.
Postby leegav » Sat Jun 18, 2016 12:04 pm
Where the easy to fit Jeff. I've got a rear diffuser and a rear wing that needs fitting... :lol:
Users browsing this forum: No registered users and 35 guests
