Megajolt was driving me mad
Tony T
Postby Tony T » Mon Sep 05, 2016 8:10 pm
i'v been moaning about my car misfiring for some months and it was getting worse for some months so time to have a proper look.First check out the wiring i found the ground wire to the TPS was not connected one of the prongs had pushed out when the plug was pushed together instant improvement.I then noticed the trigger wheel was oserlating and one tooth out
The rubber damper was beginning to fail Dick did tell me it might happen
Fitted this it's perfect problem solved all i need is a proper map
the old one weighs over 3 pounds the new one weighs 11oz :o :D
bill132hotrod
Re: Megajolt was driving me mad
Postby bill132hotrod » Tue Sep 06, 2016 3:27 pm
Well done Tony i knew you would get there in the end.
Tony T
Postby Tony T » Sat Sep 24, 2016 8:55 pm
So spent 3 hours at Sanspeed engine tuning specialists they set the carbs up and a new ignition map and it's now perfect. for about 2 years i'v tried to get it running like this i'v got to say thanks to sanspeed :D :D
Postby jeffw » Sat Sep 24, 2016 9:09 pm
Which is why spending dosh on getting a car/engine tuned is always money well spent.
