Anyone know what these are from?, I think its a Transit only im popping into the local motofactors and need a new pair
http://www.kitspares.co.uk/index.php?ro ... uct_id=114
upper ball joints! - what are these from?
Re: upper ball joints! - what are these from?
Looks the same as my ones from a transit. Not sure if left and right handed or not on a transit but you need two right handed.
Cheers Rich, do you know the year range of the transit?, the local motor factors are less than helpful at the moment
incidentally, called GBS, they refused to tell me as they wanted to keep supply "in house", not very customer friendly!!
Have you tried the bay?
These are close I think. Lots can be found from this add
Bay item number: 191410119693
They are the drag link ends from the ford transit if 18mm thread then its mk1 or mk2 65 to 86 have a look at the different makes as some are thin at the point the ball is joined onto the threaded section
cheers guys
And they are handed so you'll need a pair.
They may be handed, but depends on what is on your car. Mine has right-handed both sides.
M18 x 1.5
First Line FTR4701
qh: QD1117RHT
Veco: VB321
fai: SS5012
DELPHI: TA298
FORD: 1796515
Lemfordr: 22111017536
MOOG: FDES0874
MOTAQUIP: VDL265
MOTAQUIP: VSS265
TRW: 15ES0874
UNIPART: GSJ112
bettaparts: BBD1117R
Bettaparts: BBD1117R
M18 x 1.5
First Line FTR4701
qh: QD1117RHT
Veco: VB321
fai: SS5012
DELPHI: TA298
FORD: 1796515
MOOG: FDES0874
MOTAQUIP: VDL265
MOTAQUIP: VSS265
TRW: 15ES0874
UNIPART: GSJ112
