Does anyone know a small company who can help with setting up my Weber carbs in Southampton (ideally a small garage / company!). The engine runs fine except at tickover... everything else has been cross off the list as possible causes and I need some who know his carbs to have a look at the set up. The power is fine and when it is reving... it is just rough at tickover. I have used Neil from http://www.readperformance.co.uk and is great however his location makes getting there a pain!
Cheers Alex
Carb Tuning Company in Southampton??
- Alextreme
- andyf
Re: Carb Tuning Company in Southampton??
Tom Airy http://www.aireytuning.com was always good with carbs. He has a rolling road so can do the complete setup.
- graham b
Tom airy set my first car , tiger e1,
Miss the sound.
Miss the sound.
- andyf
He set up my sunbeam.... and I miss the sound of twin 45s at full chat
- Alextreme
Thanks... better location and had heard from somewhere else that he was good.... but was hoping that I could find somewhere in S'oton?? I can then drop the car in on the way to work... unless Tom works on Saturdays?? Alex
- andyf
Alextreme wrote:Thanks... better location and had heard from somewhere else that he was good.... but was hoping that I could find somewhere in S'oton?? I can then drop the car in on the way to work... unless Tom works on Saturdays?? Alex
I'm not sure, the best thing would be to give him a call.
Presumably the carbs have been balanced? A good balancing has sorted out a rough idle on mine a few times - I have a four manometer carb balancer, but it's in Guildford.
- Alextreme
That is a good idea... I will try balancing them. it was done last time it was on the RR around a year ago but perhaps it has no longer balanced. Alex
- andyf
It is a problem with those carbs they tend to go out of tune quite quickly
It seems I very much missed the chance to say Airey Tuning, genius with carbs and old skool
