as per previous threads....i've been asked about getting another order in for these, 'these' being the 5.75 inserts which are full LED dipped/main with LED halo for daytime driving light ( which also doubles as an indicator if wired up that way).
These fit into the 5.75 'bowls', which you'd need to have/buy elsewhere. Depending on the make of the bowl they either fit straight in, or you may need to nibble a tiny bit off the insert...either way they're easy to fit.
Price depends on 3 main factors, quantity/fx rate and also postage - cheaper the more that are bought. From memory last time around they were about £145/150 a pair.
I just need a show of hands so that I can get the pricing, then i'll ask you for commitment....
1/ Tony T
5.75 LED headlamps
Re: 5.75 LED headlamps
These are one of the best upgrades you can do. Definitely recommended.
1/ Tony T
1/ Tony T
1/ Tony T
2/ Tommo67
1/ Tony T
2/ Tommo67
- Tony T
Tommo 67 wrote:as per previous threads....i've been asked about getting another order in for these, 'these' being the 5.75 inserts which are full LED dipped/main with LED halo for daytime driving light ( which also doubles as an indicator if wired up that way).
1/ Tommo67
Hi there
I would be intrested in a pair of these, is the group buy still going on ?
Any pics please ?
Thanks
Striker-4age
Any pics please ?
Thanks
Striker-4age
there are some pics in a previous thread as this will be the 3rd time or so that we've run this 'buy'....
if you use the search function in this section the previous threads should pop up....was ideally hoping that we'd have 3 buyers as that makes the postage more acceptable....unless you fancy 2 pairs
I can't find the pics
New site 4 me
One pair will be good enough at mo please
Thanks
New site 4 me
Thanks
http://www.southernkitcars.com/forum/viewtopic.php?f=4&t=7753&hilit=headlights&start=50
if you scroll down the link you'll see the led insert fitted into a 5.75 bowl......
Ok looks good, how many lumens are they ?
So is there a sidelight, dipped and mains led bulb inside ? And an indicator?
Easy to wire ?
Thanks
Easy to wire ?
Thanks
Any pics of the light they produce ?
Thanks
Thanks
