Oil breather setup.
Oil breather setup.
Postby b33fy » Mon Jul 17, 2017 8:34 pm
I thought oil cans were supposed to have a built in breather??. I've got three outlets from the rocker covers all connected to the catch can, the fourth hole on the rocker cover is the oil filler cap. The can is filling up pretty quickly. I'm thinking the engine is pressurising because there is no breather, then forcing the oil out one or more of the pipes. The valley gasket also seems to be leaking with pools of oil collecting, any thoughts?
Re: Oil breather setup.
Postby Dick » Mon Jul 17, 2017 8:45 pm
Yep lots of them
Postby b33fy » Mon Jul 17, 2017 11:19 pm
The oil can cap does allow breathing, so it's not creating back pressure. There are some suggestions on line that the breather system needs negative pressure, i.e. routed back to the intake.
Postby Dick » Tue Jul 18, 2017 7:04 am
Dont need neg pressure thats about enissions. The tank needs to be able to vent. The tank works best if it higher than the engine but hard to do in our cars. The breather hoses can be routed high befor the tank this helps a lot. Need to check the outlets on the engines have some form of baffle to stop spray. If thank is filling up very quick then you can put drain return to sump above oil level.
Postby Fury1630 » Tue Jul 18, 2017 11:12 am
When you filled the engine with oil, did you actually fill it? :D
Postby b33fy » Tue Jul 18, 2017 12:05 pm
Fury1630 wrote:When you filled the engine with oil, did you actually fill it? :D
I filled it to the full mark on the dipstick Tony. I prefilled the oil filter. It did take a fair bit. Looking at the capacitys 5.5 litres should be about it, though It was closer to 7 litres to get it to the Mark. Potential over fill by the looks of it.
Postby Dick » Tue Jul 18, 2017 2:40 pm
Not so sure on the overfill
