a little update, bigger one coming later:
Went out for a drive yesterday and things were going great until the engine started feeling sluggish, like it wanted to stall, so pulled over to see what's going on. Eventually realised I had a coolant leak and realised and I was dangerously low on vital fluids (car not me). So I phoned the wife (read several phone calls involving "I can't see it - oh here it is right in f'ing front of me!" but mustn't complain as she was/is the cavalry). On a side note every person that pasted me and owned a 7 type car stopped and offered help, everything from getting me water to them having a trailer, really good to see and welcomed.
Anyhow limped home and this morning set about to investigate and found a crank in one of the top hoses:
Bugger, I don't have any spare curved hose like this or even know where to get an exact replacement, but then I realised that there was a length of ali joiner and I've got a tig welder. After cutting up a few bits of cardboard to get my head around what I needed to do I ended up with this. Well cuffed! Although I've yet to get the t=car up to temp yet so....
Log from Saturday and changes on the fuel table. Gotta say there's lots of power, I didn't really get to stretch it's legs so there's no updates to +4200 RPM cells. Also I fitted a breather tank with some mesh in but still getting a lot of smoke at idle and low RPMs.
- Tony T
ChrisL wrote:And the smoke:
Is it smoke or oil vapour if it's vapour your catch tank isn't big enough the oil isn't condensing properly
Yes it's oil vapour. Struggling with space now so was going to run a tube inside the catch tank through a sponge or run it to the bottom of the tank so it gets submerged but not sure is this is a sensible approach...
- Tony T
The red one is now the ally one worked well couldn't get the filters its been modified to many times
Thanks for the pic's Tony. I'm following your lead, spent last night drilling, tapping an in catch tank connector.
Have you got the crank case going to the catch tank as well and the cam?
- Tony T
ChrisL wrote:Thanks for the pic's Tony. I'm following your lead, spent last night drilling, tapping an in catch tank connector.
No not yet I've got two ways to go not show. one way is a pipe in to an air cleaner or as you say in to the sump.at the moment I've got 2 Pipes one big one from the back of the cam cover Wich I fitted and small pipe at the front original and some mod's in the cam cover. I'm thinking in to the air cleaner because it's easy you can see both pipe just in this pic
Hi remember me?
So suspecting compression issues causing the oil I've run a compression test and the results are poor, this is in PSI, I checked twice!
Cyl Dry Wet
1 25 45
2 10 50
3 25 50
4 60 135
So by my reckoning (bearing in mind I know nothing) I'd say it's fooked probably both valves and rings.
I think this is probably a result of it overheating so looks like I'm in the market for a 2.0 ltr Blacktop Zetec. Anyone got a good one knocking about that they want rid off?
Cheers
Chris
Cyl Dry Wet
1 25 45
2 10 50
3 25 50
4 60 135
Cheers
Chris
Sorry to hear that
Users browsing this forum: No registered users and 52 guests
